Hi,
I have some issuses after the Arlo App update in Denmark for a couple of days ago, is there anyone who have the same
issuses..?
1, Geofencing are not working anymore, when i´m outside the zone it´s still offline.
2, No alert on the phone when motion are detected.
3, When i try to access a link on the Computer from 12/3 it´s has expired.
4, When i watch live feed on the phone, and turn it off again it tells me that
it was 4 days ago i watch the live feed (down to the left in the live feed window).
I have Version 2.4.7, released 4/3-2018
Any solutions will be great
Best Regards Dr_Henning
Easy thing to do is un-install the app and re-install same.
Many times this fixes issues, unknown if it will work for you but not a hard thing to try.
Hi Again,
I dident yet re-installed the app, but now i get an Alert on my Phone, but with a 5 Minutes delay..
If i try to re-install the App, do i need to re-sync the Camera´s or other stuff..?
Is it just me, but every time they update the apps, something is wrong, they fixed the Zoom issue
thats one thing, but 2 or 3 things are now worse..
Thanks..
Reinstalling the app does nothing to your setup. Remove and reinstall at will.
