Is there a after market add on for a siren availaable on my unit. If so the modle number and where is it available.
No ,there is no device,..... tho if you use IFTTT, you may be able to work something up
Siren comes on the PRO base unit, will will be available by itself soon ( the pro base works fine with the older cameras too )
Please offer an outdoor Siren option ASAP! I have people trying to get into my vehicle and need an exterior siren to sound! Is there an approximate date when an exterior separate siren will be available?
TomMac's suggestion is the best one. You could purchase an IFTTT enabled siren then simply set an IFTTT rule when your cameras detect motion. IFTTT is extremely easy to use, and free.
