Argo Pro just bought - 1 of cameras battery goes dead after 2 days
I just bought this 2 camera system with base - 1 camera is holding charge just fine but other one is going dead every 2 days - both are outside in same general location - is the battery defective?
Take the bad camera and go to settings...
us REMOVE DEVICE to remove
open battery door , pull battery and then replace.
charge up battery ( plug in to outlet )
Bring back the camera as in new ( sync )
* the above will eliminate any possible glitches and restore the camera defaults....
If the battery still goes doa quickly, contact Netgear.
Replace? I just bought this - does netgear replace or reimburse?
Depending on where you purchased the PRO, you may have the option of return to the store...
If not then Netgear is your only warranty option... Contact them and ask, TBMK, it's a swap .
