I was wondering if I need a token reset.
Arlo cameras stopped working in HomeKit.
I removed them from HomeKit and now when I try the set things up again, the Arlo App gets stuck in “discovering” and never does anything else.
Can someone help?
Thank you
Thank you. I’m just now getting around to try and reset things up.
How “nearby” do the cameras have to be? Like should I bring them down from their mounts and have everything inside the house to set up?
it’s been a while since I did this.
If they are already installed, just follow these steps: https://kb.arlo.com/000062279/How-do-I-connect-my-Arlo-device-to-Apple-HomeKit
