App Says The Base Station Is Offline
  • 2 Replies
  • 1563 Views
Retired_Member
Not applicable
Same question as others. My power and internet light are on but the camera says yellow. My app says base station offline. But the base station says not off line. My camera is synced. It worked for the past month and just stopped. Please help. Thanks.
start with easy things first...
Check cameras batteries, if pulled/replaced it should auto resync
reboot the base with the power button
if NG, then
use remove device and bring back camera ( rebuild modes, settings ) as new
A solid amber Camera LED means the base needs to be claimed. Nothing will work until that happens. You can try just using the Add Device button on the Devices tab to claim the base but you may need to remove everything from Settings, My Devices and start fresh.
