Any suggestion/solution to mount Arlo Pro camera on a window surface?
It would be nice to be able to mount the Arlo Pro camera flush on a window surface. That way I can place the camera inside the house behind the window glass looking out to the front or back of the house. That way the camera is protected from the elements and from anyone trying to steal the camera if mounted outside. Or even mount the camera on the door sidelight window so you can see who is at the front door. I think I can use a silicone glue and glue the camera to the window, but that is not a real solution. Has anyone suggested a solution?
Any suction type mount with enough adjustment to allow the camera front to touch tight up to glass...
the threaded hole is camera standard 1/4-20.... so almost any mount is standard.
Or off to side camera mount that can adjust up to the glass
Even so, motion detection won't work through glass so it may be a moot point unless you have an external camera to trigger detection.
