Is there a manual that defines the terminology and function for the cameras? For example, what is geofencing and what does this do?
Also, with this new app will loading the camera get quicker? I like to turn my cameras off when I’m home to save battery life.
Thanks for your help.
Hi Girly,
You can refer to the Arlo Support Page if you need to find any articles or help.
To learn more about Geofencing, you can read more about it here: How does Arlo Geofencing work and how do I set it up?
To learn more about how to turn off your cameras, you can read about it here: How do I use the Arlo privacy feature?
I am having problems with one of my batteries staying charged. The other 3 are working fine. Do I need to replace it? The battery is not even a year old.
If it is not charging properly, you may need to change your battery. Feel free to contact the Support Team to help you out. You will find several options for contacting support in the provided link.
