  • 8 Replies
  • 4199 Views
Johnny290
Mentor
Mentor
The Android app is very slow the live feed often and freezes. I have a Samsung S8 plus with all the latest updates I have very fast internet connection speeds. By the time the live feed starts the people at the front door are gone. And forget about talking to them with that crappy speaker
8 REPLIES 8
Johnny290
Mentor
Mentor
Well I had a WiFi extender plugged in I was not connected to it but when I unplugged it I found the Arlo app started working better possible solution here just to let everybody know
2.4GHz interference, whether WiFi or other, is always a possibility. If the issue is the same for all cameras, I'd suspect something near the base while if only one camera is affected I'd suspect something near that camera.
Johnny290
Mentor
Mentor
Thanks for the information
Johnny290
Mentor
Mentor
Well the Android app was working well for me for a few days at least now it's lag lag lag. I don't know how this can be a security system
Johnny290
Mentor
Mentor
Might be WiFi interference because when I turn my wifi off it works better
anudeepb23
First of all you should know some of the troubleshooting methods ,
I will answer this from non-general point of view ,i.e., technical point
Lots of Android device come with  useless apps pre-installed and this happens in each and evry mobile whose OS is android
there is another occurence , manufacturer will load your phone with “experience enhancing” apps
In addition to the above,bloatware is not only affecting the speed and performance of your Android phone, but they also drain the heck out of your battery. A great app I found to identify these nasty apps is “Package Disabler Pro”, that identifies them for you and lets you disable them manually.
Once installed and opened, you will see a long list of Android services.
i am answering this from android training
Johnny290
Mentor
Mentor
A while back I had this problem I have a S8 Plus phone I turned off power saving mode for a wifi in advanced options and that's not my problem
Johnny290
Mentor
Mentor
Correction I turned off power saving mode for wifi and that solved the problem
