Always poor camera connection even 2 meters from base station. Help?
I have just bought and installed Arlo Pro cameta and by checking positioning app noticed that it shows always bad connection. What can it be? are there any utilitys to check if WiFi network of the base is properly tuned to the enviroment?
One ore strange thing: When camera arrived it showed 1% of charge, after 5 minutes of charging it showed already 100% is it normal?
Based on comments here, it seems like the camera positioning WiFi indicator may not be functioning properly. I'd use the one in the Devices tab for each camera as well as the percentage shown in Settings, My Devices, your camera instead.
