Alro Pro base station is offline. middle LED unlit
  • 4 Replies
  • 3409 Views
Ankrich
Hi All,
My Arlo pro base station went offline today morning. I know this is a glitch with Alro but this time even after power cycling ( restarting) the base station ,  Router/modem and NBN ( fire to home box) it didn't trun online.
The middle light is off and no matter what I do its not working this time. I have done the above power cycle method in past and then it used to do the trick..
It frastrating as when you need the most this system just stops working.
AnkRich
The lack of any color Internet LED says it's sim[ply not talking to the router. This can be due to the base, cable or router. You've power cycled things - good. Have you changed cables and router ports? If still no go, it's likely the base. Open a case with support here to get an RMA.
Ankrich
Thanks for your response. Yes I have tried replacing the ports and switched the cable as well... No issues there.. When I check the connected devices on the network, the base station shows up with port.
Could you please help me with this issue?
Ankit
Ankrich
How do I raise.a support case?
Use the Contact Support link at the bottom here and again on the new page that opens.
I'm surprised that the base shows in the router's attached devices list with the Internet LED out. It should be amber at that point.
