Alro Pro Camera Too Bright
  • 2 Replies
  • 3282 Views
XDoor
bought a set of 3 Arlo Pro Cameras from Costco, and used them for approximately 4 months now. one of the cameras became so bright and you could not identify anything. I have tried to remove the battery and change the setting, however, none of them had worked. is there anything else I should trying before bringing them back to Costco?
Use live view o the camera and click on the "sun" icon. Adjust the brightness and be sure to save the setting. You'll have to refresh the live view to see the difference.
XDoor
thanks
