Started from Sunday all of my three arlo devices stopped detecting motions.
I have tried following:
1. reboot my base station. No help.
2. tried motion detection test: works properly (can see amber light flashing)
3. checked settings and all enabled for motion detection and sensitivities set at 80%
4. checked camera live view. All works properly
I don't think it is a problem of any of the devices since they all three stopped working altogether. Not sure how to trouble shoot in this case. Thanks!
I found the cause. The base station was disarmed 😛
What camera models do you have?
Hi Stephen my model is the first gen Arlo Pro. Thanks.
Thx. Have you tried making a manual recording?
