  • 1 Reply
  • 907 Views
merrillbalan
all 4 systems freeze.  If using microphone all connections freezes including the video and voice and this happens to all 4 of my arlo's.  all are updated on fw and 3 of them are new purchased too.
H8
Serial Number4XH2727BA05BE
Firmware1.092.0.17_25364
Streak2
Master Master
I you are using an app to view the cameras then try and use a web browser https://arlo.netgear.com/#/login instead to see if the problem goes away. If it does, then try and re-install your app.
If your using an Iphone X model then there are known issues with the app on these phones.
