Alarm Activation Rules
Hi All,
I was considering buying an Arlo Pro and wanted to know if there is any ability for you to receive a call on your phone rather than a text when the alarm is triggered. If not I believe there is a way that you can change the settings on your phone so the phone rings when you receive a text from a specifc number. Any help would be appreciated. Thanks
You can do this with IFTTT. There is an existing applet just for this. Or you can create your own.
https://ifttt.com/applets/413211p-if-arlo-detects-motion-call-my-phone
