I have a rule showing with more text than other rules, its "if motion on" or motion/audio.
Other rules just show the name of camera without the additional text, whats going on?
surfer1000,
Have you tried to reboot the base station and re-install the Arlo Mobile App?
5 REPLIES 5
surfer1000,
What device are you using when this issue occurs & does this happen on the Web Portal as well?
Hi im using my Galaxy S9+ Android phone. It's showing normal on web portal, every camera on the portal shows… "on motion" or "on motion and audio… "
surfer1000,
Yeah reinstalling app then re-adding my rules has them showing correct now
