  • 4 Replies
  • 2603 Views
sacornel
In a custom mode, I have 9 rules for 9 cameras.  The Add Rule button goes missing when I try to add a 10th rule.  I’m trying to add additional triggers, which i’ve done in the past, but for some reason it’s not letting me.  Any help is appreciated.
Wklovelace3
Virtuoso
Virtuoso
Only one rule per camera
sacornel
How can I tell Camera A to record if Camera B detects motion if the Add Rule button is missing? This is what I’m trying to accomplish and I’ve been able to do it in the past. Thanks for the help.
Use Add Device instead. Same thing.
renatoharo
In the particular case explosed before, having CAM2 record id CAM1 detected motion it may be the same, but, how do I create a mode where CAM1, CAM2 and CAM3 record and send ntifications if they detect movement; but CAM4, CAM5 and CAM6 only record (w/o the notification)?
