  • 5 Replies
  • 3737 Views
bluebait
Is it possible or am I overlooking it, to activate all cameras when one senses motion? I have the Arlo Pro system with four cameras.
You must first add a NEW MODE
create the rule ; A cam senses, A records.
Save it
Now go back and edit it adding the next rule
A cam senses, B records
save
repeat as needed .
They should all record when A senses motion
5 REPLIES 5
"nested rules" ...
Cam A senses, A records
A senses, B records
A senses, C records
ets
bluebait
I can see where I can use one to activate another, i.e. A senses B records but that wouldn't allow A to record would it? Nor do I see how I could activate more than one camera when another senses.
Save it
save
repeat as needed .
JerryR
Luminary
Luminary
I wanted to do this but couldn't through the Android app. It would only allow 4 of the conditions I needed. I was able to set it up through the website, though.
bluebait
Ok, I understand now. Got it set up. Thank you
