Hi,
I would like to ask if you can make access to speak availabel to guest users, this helps with husband and wife situations where you both need acess to the same camera, I appreciate we have to have separate log ins, but the ability for either of us to communicate would be most helpful and I am sure beneficial to others. Thanks
peteles,
Make sure you have "Allow Access Rights" toggled on the primary account for the shared user. This should allow the secondary account to access the microphone feature.
peteles,
Thank you so much,
We just hadn't scrolled down far enough to see there were more options available.
All sorted, with additional peace of mind now!
