About half of the videos will not play using the Android app or using a browser on a desktop. Using the Android app, I will click on the video and it will start to buffer and then stop and just go back to the play icon that overlays the video. On desktop, it just tells me that playback of this video is not supported in the browser and for me to download it. This don't make sense, since the other half of the videos play just fine on both the Android app and in the browser.
d/l some that have issue and try a playbck local... this will help you find where the issue is.
Also try a different browser
A congested upload pipe and/or signal quality may be an issue. What's your upload speed as measured by speedtest.net? Do all cameras do this or just some?
Try removing and resyncing a camera to see if that helps. If not, you're left with a full system reset, removing all devices in Settings, My Devicees and starting fresh. Be sure to note all settings, modes, rules and schedule before doing so to speed rebuilding.
