  • 4 Replies
  • 3618 Views
itsjosh33
Im running two Arlo Pro cameras and one base station.  I stream everything and usually have 2-3 devices on internet when Im home.
I'm getting some delay and pixelation- running the latest firmware. Is my 30 MBPS download and 3 MBPS suffient enough?
What are you all running?
Thanks!
Generally, 3Mbs should be fine although possibly minimal. It may be useful to try reducing the video quality to see if that helps.
Maybe not..... It could be the upload.
the Pro can peak at about 1Mbs + on the highest Rez... Tho prob closer to 750K.
Try and lower the quality a bit and or test with only one streaming....
Also , pixelated video can be from interference.
I run much higher speeds than yours.
itsjosh33
I live in a higher end apartment complex. I'm wondering if it could be interference from all my neighbors.
steve_t
Master Master
Definitely. Download a wifi analyzer app on your phone and check out all the 2.4GHz networks. I'm picking you'll have dozens
