ARLO PRO PLAY SOUNDS Automatically or Remotely
  • 1 Reply
  • 4712 Views
chaseroni
I would really like to have the capability to play a recorded sound after audio is detected. Either automaticaly or remotely. My dog barks for an hour or two every morning when I leave the house and I can make her shut up by playing a high pitch recording into my phone from a different device. It would be extremly helpful if there was some funcionality within the app to make this possible without the other device. Has anybody came up with a solution for anything similar?
steve_t
Master Master
You'd probably need to look at something like Samsung Smartthings and a speaker that integrates with it. Arlo has integration with smartthings so can trigger other events. I have my Arlo Pro trigger outside lights when motion is detected between sunset and sunrise. I'm sure someone has done something similar over on the smarrthings forum
