4VR16B73B6501 Arlo Pro Camera goes off-line, says battery needs recharge.
Hardware: VMB4000r3
Firmware: 1.8.2.4_10232
Ser.No: 4R026B74A683B
Camera info:
Hardware H7
Firmware: 1.090.0.1_11011
Ser.No: 4VR16B73B6501
I have two cameras. Both had fully charged batteries. Camera 2 shows good battery life, almost full, and operates normally. Camera 1 however, goes off-line and will not reconnect. Approximately twelve hours later, the app displays that it is time to 'change your batteries' and shows battery level at 1%.
Both cameras look at the same amount of traffic but from different angles, so one is not more active than the other. Why is Camera 1 disconnecting and then, within 24 hours, telling me that the battery is only at 1%? I have changed the battery with a spare and it does not appear to be a faulty battery. What situations would cause this Camera to a) go offline and b) for the app to say it only has 1% battery? The connection also states that the camera is linked to the base station.
If swapping batteries and locations around don't help, it would seem to be faulty cameras. Open a case with support or swap the system at the store.
