4000 base station
My 5 cameras disconnected from the internet.
I've tried EVERYTHING to reinstall the 4000 base station, but it could not be "discovered"
@Joanell wrote:I've tried EVERYTHING to reinstall the 4000 base station, but it could not be "discovered"
Did you try the reset procedure?
Did you try onboarding again using your phone? A PC (my.arlo.com)? Both?
yes, ... cell and laptop...
done the factory reset numerous times
still can't discover any arlo products
What is the LED status of the base?
The left and center lights are a solid green, the right light is a solid yellow
Is the PC you used for onboarding connected with ethernet or wifi?
Are you seeing the base station in your router's attached device list?
