  • 5 Replies
  • 1850 Views
Joanell
My 5 cameras disconnected from the internet.
I've tried EVERYTHING to reinstall the 4000 base station, but it could not be "discovered"
5 REPLIES 5
Did you try the reset procedure?
Did you try onboarding again using your phone?  A PC (my.arlo.com)?  Both?
Joanell
yes, ... cell and laptop...
done the factory reset numerous times
still can't discover any arlo products
What is the LED status of the base?
Joanell
The left and center lights are a solid green, the right light is a solid yellow
Is the PC you used for onboarding connected with ethernet or wifi?
Are you seeing the base station in your router's attached device list?
