3 Arlo Pro Solar Panels Dead, Oldest Was 3 Months.
I’ve been replacing my arlo cams with arlo pro, and buying the solar panels because the ads literally say I’d never have to charge a battery again. I noticed today that all 3 of the solar panels are no longer charging. The oldest was about three months, then one month and the newest is about a week. All 3 are on different sides of the house. Does anyone know of a different vendor that makes compatible solar panels? I’m going to keep the rest of my arlos as the original model. No reason to spend another $1000 on cams and chargers if the chargers die so quickly.
Are you able to get the solar panels replaced under warranty? I've had mine for over a year with zero problems. The camera attached to it has not been touched in over a year. I'm always suprised at how low the light can be and the camera shows it's being charged. The panels do seem oversized though
Besides the batteries running down, what indication do you have that the panels aren't working? Error messages? Battery icon not showing charging?
Batteries dying and the charging symbol no longer shows.
What happens if you plug the cameras into the wall charger?
