2 questions
Preface I have 3 pro 5s cameras
1st: is there a way to watch all cameras live simultaneously?
2nd: is there a way to have an audio clip played whenever motion is detected?
With iOS you can configure Siri to announce notifications.
I haven't used Android for a while, but I believe there is a way to turn on voice notifications there as well.
You should be able to do that both on the phone and on a PC using my.arlo.com. Though on the phone you might not be able to see all the cameras at once on the screen (without scrolling).
Details depend a bit on whether you see "Library" in the app, or whether you see "Dashboard" and "Feed" instead.
Note the livestreams will time out after a bit (20-30 minutes), there is no way to prevent that. Livestreaming continuously will drain the batteries fairly quickly, so if you want to do this a lot you might need to connect the cameras to AC power.
