I bought the 4 pk Arlo Pro cameras, 3 are synced, but the last one is blinking orange and won’t sync. I’ve read that these cameras come with a full battery. Any suggestions on what I can do! Thanks!
Pull battery, use the ac cord only and see if it syncs....
If so then insert battery to charge
I did jus that, it synced but won’t stay on when I put in the battery. So I decided to swap batteries with a synced camera and the battery full, but still won’t stay on. And now I can’t sync my 4th camera. Thank you
Swap at the store or open a case with support.
