Rural Property-Single Subscription
  • 2 Replies
  • 739 Views
J_o_n
I’m planning to buy Arlo cameras on a farm to mount to four separate locations on sheds about 3-4 km apart. Possibly will use starlink at each location as 4G coverage is poor.
Will this subscription be considered one address, or as it runs along a highway will it be considered 4 seperate addresses needing 4 subscriptions?
Edinburgh_lad1
4 separate subscriptions, I'm afraid, which adds up to the cost.
Also, if this is to monitor a property that is not going to be occupied for periods of time, I suggest a wired system.
If you need geofencing at more than one location, then you would need to get four subscriptions.  Otherwise you can get by with one.  Note that if you want to schedule the cameras, you are limited to the three modes (which control all the cameras in the system).  There is a custom modes feature that will let you set up independent schedules for all cameras, but that is still a work in progress.
  • 2 Replies
  • 739 Views
