I have a smart hub but can’t get the Micro SD to work. In Devices in the App none of the changeable swipe buttons work nor will it format the micro sd. I am on the 1 month free subscription does this limit the device use
Thanks. It was a formatting issue. Had to download a formatting tool off the web to a Windows 11 PC so it could be formatted to a format type the hub could read and write too. After trawling the internet for assistance I eventually found a fix.
The trial subscription has no bearing on the ability to set up and use local recordings.
Is it possible that the card isn't fully inserted (should click into place and be flush with the case)? Is the card at least 16GB? Until the card is enabled/formatted, nothing is going to work. Maybe try a different card as well as reboot the hub would help.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
