Blur part of the view
  • 2 Replies
  • 1374 Views
Chris-nor
My camera records part of my neighbours property. Can I blur or remove part of the view from my Arlo Pro 5 to give them privacy? It is not possible to adjust the camera angle enough.
There is no feature which does that.
If you use a threaded mount, you may be able to reposition the camera sufficiently to eliminate the neighbor's view.
