local storage
  • 1 Reply
  • 868 Views
SouperGuy
I recently upgraded my Arlo to the 5S Pro with a 4540 base station.  Once the free trial was over, I set up my base station to record videos locally.   I set up everything properly on my base station and my modem for Port Fowarding and it has never worked.
On June 18, 2025, I finally contacted Arlo support, and they told me I need to contact my internet provider to request permission for traffic to be allowed through the external port that is define by the Arlo Secure App.  Well, I did that and nothing has changed.
However, ever since I contact Arlo support and they asked me for my base station SIN number, now I cannot even download local videos from my home.  I was always able to do that and since I contacted Arlo support, I now have a useless security system that does not download any videos.   When I contacted Arlo support, they said they did not do anything, but I don't believe them.
I don't know if anyone else has had this issue and provide a suggestion, but at this point, I feel I wasted a lot of money to "upgrade" as the old Arlo system worked much better.  I get the feeling they are doing this to get people to pay for a plan.  I will keep trying to fix this issue but if I cannot, I will trash this system and go to something else other than Arlo.
Have you tried both using the Local setting in Feed as well as looking in the hub's settings under Storage Settings to see if the videos are there? Is a VPN in use? If so, disable it. Do you get an error message?
It may be worthwhile to reboot the hub to see if that helps.
