  • 2 Replies
  • 8231 Views
  • 2 Likes
dboskee
My VMC4030 cameras are reaching EOL. I am considering buying the Pro 5S 2K cameras. Are they compatible with my VMB4000 base station?  Or will I have to subscribe to Arlo Secure?
Yes and yes.
First, your cameras aren't going to stop working. They won't get any more firmware updates but it's been a long time since they did get updated. Eventually, new hardware/firmware/apps will cause the EOL devices to no longer work but that's not in the foreseeable future. You still get the free 7 day plan, too.
The Pro 5 can connect to your existing base or your WiFi so you'd have a choice if you wanted it. However, any camera newer than the Pro 2 requires a subscription for cloud recordings. If you buy any new camera, you'll need a sub.
Yes and yes.
dboskee
Thank you for that information
