  • 7 Replies
  • 1742 Views
GCJersey
Hi, It seems like I am unable to setup my Pro 5 2K cameras I have just purchased from Amazon. Arlo Secure app is not even giving me an option to select one. Only Pro 4 is available as latest hardware. Can someone help. Arlo Pro 5S 2K
Best answers
  • StephenB
    @GCJersey wrote:
    It’s not even about the subscription plan. I am jot even able to add the can to the app itself. All other Pro models are listed thou.
    Understood.  Arlo only puts the Pro 5s on the list in places where they offer subscriptions for the camera.  Hopefully they will change that soon.
    One option is to set up a VPN that terminates in the UK, and set up a new account with that VPN in place.  Then disconnect the VPN, and add the cameras to the new account.
    (If you are traveling to the UK soon, then you could alternatively create the account there).
7 REPLIES 7
Where are you located? I would expect the Pro 5 to be available worldwide by now. Make sure you have the latest app since old ones won't support new devices.
GCJersey
I am located in Jersey , Channel Islands- which is kind of part of UK.  There is nothing mentioned on Arlo’s website or Amazon about any geographical limitations hence my surprise and disappointment.
The "kind of" may be the issue. This FAQ details where subscriptions are available but I can't be sure of more unusual locations such as yours:
https://kb.arlo.com/000062249/Where-is-Arlo-Secure-available
Did you reboot the phone and reinstall the app?
@GCJersey wrote:
I am located in Jersey , Channel Islands- which is kind of part of UK. .
"Kind of" being the key phrase.  I think this is similar to a US territory, so subscriptions might not be available there.
Do you have other Arlo cameras?
GCJersey
Just Pro 5s.
GCJersey
Yep. I have restarted the phone several times and that didn’t help.
