My wife shared an invitation to link to her account. When received it is asking me to repeat the setup / sync steps to sync my phone app to the camera. Is that the only way to get this done? Squirrel box is 15 feet up a tree
No, you don't do that.
The simplest approach is for you to use her Arlo credentials in the app on your phone, Then you will have all the controls she has.
If for some reason you want to use the "friend" feature instead, then the next step is to have her check that the access was granted from her account.
Also, do you see "Feed" and "Dashboard" in your app menu? Or do you instead see "Library"?
I have both dashboard and feed. Feed has a pop-up message that I need to plan to view recordings. Dashboard shows a personalize your dashboard but add a widget is grayed out.
and she added me as friend, received the email ..." - has invited you to access their Arlo account....click here"
Understood. But she still should check that the invite was accepted in her account.
You could try clicking on the "create account" link on a PC. That will open your browser to my.arlo.com. From there you fully log into you account. Using a PC tends to be more reliable than using your phone.
Once done, you should see two "Home" locations on your main screen. One will have no cameras, the other has the shared cameras. Rename one to avoid confusion.
Once again, IMO the best approach here is to use the same account on both phones. That gives you full control of the cameras and eliminates the confusion of having two locations.
status of request is "pending" in her account
Then try again using a PC (as I suggested above).
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
