Rule-Based Automation for Siren Activation
Hello,
I am using an Arlo system with three cameras. In the current version of the Arlo app, under "Automations," I only see options to create schedules (based on specific times of the day). However, I would like to create a permanent rule that works in real-time, not on a schedule.
Specifically, I would like to set up the following automation:
- If the garage camera detects motion (or any intrusion),
- Then all cameras in the system should activate their sirens simultaneously, not only the one that detected the intrusion.
At the moment, I cannot find any way to configure this kind of rule-based automation in the app. Could you please confirm if this feature exists, and if not, whether it is planned to be added in the future? When I try to set this up, the “Add device rules” option is greyed out and I cannot select it.
Thank you in advance for your assistance.
Note I don't work for Arlo.
This wouldn't be an automation in their framework. Instead it would be a camera rule inside the modes. "Activate Siren" is an option in those rules now, but "Activate All Sirens" is not.
Arlo generally won't commit to future features here (custom modes being a rare exception).
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
