I have had an Arlo camera system since 2017 with a VMB4000 base station, including 3 Pro cameras and 3 Arlo Essential XL Spotlight Cameras. My system works perfectly.
Now, in April, I purchased 3 additional Pro 5S 2K cameras, and unfortunately, they do not work. I did some research before buying them, and according to the website, they were listed as compatible.
I’ve tried several ways to connect them, both using the VMB4000 base station and directly via Wi-Fi, but nothing works.
The problem is that the Pro 5 camera does not appear in the options to add to the app. And when I try to install without the base, connected to a 2G network, it beeps when I scan and does not find the camera.
so I can't use the camera.
I live in Brazil and I’m unable to return them. I also don’t have a subscription. So I can't use the camera and I can't go back to the US to return it.
Could you please help me resolve this issue?
Best answers
Thank you for your interest in the Arlo Pro 5s. Currently, this camera isn’t available in your country because Arlo subscription plans aren’t yet supported in your region. We’re always working to expand availability, and you can check the latest list of supported countries here
When will ARLO fix this problem for use anywhere in the world?
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
