Pro 5s 2k mic
I recently purchased 9 arlo pro 5s. The mic on all of the cameras do not work. The audio works fine, the push to talk doesn't. Any suggestions?
If you hear audio in the recordings (or while livestreaming), then the microphones in the cameras are all working.
Is the issue that you cannot hear the person talking when you use push-to-talk? Or that they cannot hear you?
If you have a headset or earbuds, then try using that instead of the phone speaker, and see if that changes the symptoms.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
