Pro 5S 2K charging question
If I disable my cameras when using the solar panel, will it assist in allowing the camera charge faster? It's my understanding the solar panels are intended to be trickle chargers for the purpose of keeping the camera "topped off". Basically I attached it with cameras at 50% and I'm trying to avoid disconnecting them to charge given their hard to reach locations.
Arlo hasn't said, but I suspect the power use when "turned off" is the same as when the camera is disarmed.
If they are really inaccessible, you might consider getting the XL upgrade kit, as the XL battery has 2.5x more capacity than the standard battery. That will give you more margin to get through periods when there isn't much sun.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
