Pro 5S 2K camera won't fit in housing
The camera won't click in and fit securely inside the white camera casing -- sticks out 3/8 " when pointed down and remains loose. How fix?
Message 1 of 3
57
Try getting some silicone grease, and applying a small amount to the O-ring on the camera body.
Message 2 of 3
53
I use both thumbs on the edges of the camera with my fingers wrapped around the case to make sure the camera clicks into place. 3/8" may mean something is keeping the camera from being inserted properly. Check both the case and the bottom of the camera.
Message 3 of 3
45
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
