Pro 5
How do I make the light on my pro 5 come on when I turn the camera on to look around, I can do it manual but will not stay on when I go out and come back to that camera.
Define "go out and come back" - you leave the house or leave the app and return to it?
Leave the app or I go to another camera and then come back to the camera that is having the problem
If I understand, you're saying that you can live view a camera and turn on the spotlight. Doing anything that causes live view to cease but then returning to the camera to again live view does not allow you to turn the spotlight back on a second time. Correct?
I just tried this on one of my Pro 5 cameras and had no problems turning the light on at any point. I guess I'd suggest removing, resetting and re-adding the camera as below:
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
Actually, I think @georgestgr1965 is expecting the spotlight to stay on until it is manually turned off. If I am right about that, then stopping the livestream will turn off the spotlight by design. Doing a factory reset won't change the behavior.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
