Pre-Purchase Questions of Public Entity
  • 1 Reply
  • 667 Views
nvitalian
We are looking at, to start, 7 Pro 5S 2K cameras. 4 outdoor and 3 indoor.
Due to the size of the building and location of Switch Stacks, we are unable to use the Ultra 2's. With cinderblock walls it's a tomb, but we do have AP's throughout the building.
Questions:
Can the web portal display more than 4 cameras at once?
Can there be more than one display signed into the portal at a time?
Can anyone weigh in with their experience using Arlo in a semiprofessional environment?
I'd really like the Arlo solution to fit as I've had peers use them in other situations with great success.
If we can get this to work, we could expand the solution and there is the possibility of it expanding to other public agencies we partner with.
1) The display of cameras is related to the video resolution used on the computer as well as the size of the camera widget. The widget is add to the Dashboard screen while for the Devices screen you can't set the size. A little trial and error may be needed.
2) Yes, multiple people can view the portal at one time. There's 2 ways to do this - share cameras with other email addresses which can be used to limit what the others can do (or not) or to provide the primary user's credentials to all authorized personnel which gives them full access to the system.
3) I've only used the system in a home environment - sorry.
