One camera too far
Hi there,
I have 5 Pro 3 at home but one of them is too far from the base and disconnecting all the time. What is my best option here, simply buy another base to extend the signal? Or better to replace this camera with a more modern one which can connect to the wifi? Issue is that I would lose the local storage without the base right?
Since the hub is basically a stripped down router, the same solution applies to either approach. It's easier and cheaper (once a new camera is purchased) to extend WiFi as opposed to buying a second hub. A second hub has to use an Ethernet cable to connect so you're likely extending your WiFi in the first place to allow this. For me, that seems to lead to extending your WiFi as needed and using a newer cameras to connect to that.
YMMV.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
