May 2025 Smart Detection - Battery Drain
Since the upgrade, my 8 Arlo 5 Cameras lose about 2% of battery per hour and 4 of the cameras have solar panels. I'm ready to cut my losses and move on from Arlo, but I thought I would see if anyone is experiencing the same issue. I know the upgrade caused my issue as nothing has changed for two years and everything worked perfectly. I have tried everything possible, including starting over, but continue to have a system that is worthless. My doorbell has never had an issue and the battery drain is happening on that device as well. Any help, please....
This may be due to a connection issue for the cameras. Are they connected to WiFi or to a hub? How many total minutes per day of recording and live viewing are the cameras providing? 5 minutes or less per day is the spec. You may need to remove activity zones to get a true reading of the totals since a recording is made but the servers may throw out the recording based on the zone settings.
Weel, here is what I know. The system has operated correctly for two years except for the cell backup feature on the keypad. That issue was fixed by Arlo 2 months ago. I have 20 motion sensers and have been connected with the secure link on all cameras. The solar panels have maintained the cameras for two years with the exception of a couple times where needed to swap out batteries. The camera's do not have zones setup, and I rarely receive notifications, maybe a handful a week, which is a 10 second recording. Again, no problem for two years. I also have 2 wireless keypad, and they have worked great. If not for the cell issue, I would have changed my parents from Ring to Arlo, but that held me back. I should mention, I was gone for three weeks and during this time the only thing that changed was the upgrade and within a couple days every camera was going dead before I could get home. I have been working on this issue for the past 4 days, I have factory reset every camera, connected directly to internet, did 2.4 only, added sensors, eliminated cameras, downgrade Arlo service. I thought maybe my batteries are an issue, so I bought 3 XL batteries and those are draining down just as fast as the regular batteries. Yesterday, I disabled two cameras that are connected to solar panels, so I could tell if they would charge up a little - nope (stayed the same though) and once it got dark, down go the batteries. I have my sensitivity down to 25%. I purchased a Reolink Cellular Camera today, so I will have a peace of mind when I leave for a few days. Maybe it is interreference of some kind, but I'm just the guy that buys the cameras and I want them to work. Arlo owes me a ton on money if they want to pay me by the hour, while I'm troubleshooting this crap. I manage my parents Ring camera setup and never have an issue. I read online, which I should have done prior to investing as I see post after post on battery issues and no answers except too far away from the router or too much activity, well I do not have these issues. Remember, it worked fine for two years and when I'm gone something changed.. What?? UPGRADE / POWER CONSUMPTION.... I will probably be selling my $1500 Arlo System for $10 on Craigslist...
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
