  • 2 Replies
  • 4328 Views
DArl1
Hi!
on the new UI i dont see the option to switch to local storage view .. the only way is to go to the base station and view from there…. Is it an option to view local clips under feed tab?
With the new UI, local recordings are found in the hub's settings under Storage Settings. They will show when you enter there.
Best answers
  • jguerdat
Edinburgh_lad1
Nope. So, they forced this new UI onto you and as a result you're disadvantaged because they've renamed library to feed, and in order to find your local storage videos, you have to carry out more operations than previously. I'm actually surprised that there hasn't been an outcry about that yet.
