  • 4 Replies
  • 3390 Views
Kkmok
If I am using the Pro 3 Floodlight camera in my backyard, what is the best light setting to scare animals away? Should it be set to 100%, or is 67% still good enough? Many thanks
Only testing would tell. You may also want to try the Pulsate choice in the camera's Light Settings under Behavior (it pulses kinda like every .5 second).
Kkmok
Many thanks, @jguerdat
Kkmok
Wonderful. Much appreciated. Will try it. Thanks
