Hundreds of sound detected notifications per day
  • 3343 Views
johnvenets
Did a firmware update a few days ago and ever since have been getting hundreds of notifications each day for “sound detected”. I’ve checked the settings and sound detected is turned off (under Away/Home/Standby). This is draining the battery (down to 15% in 4 days).
This is VERY annoying.
HELP!
Try removing one camera (if you have others doing this too) from your account and add it back in to see if that fixes the issue. Be sure to edit your modes again to verify audio detection is disabled.
johnvenets
Thanks.  That worked!!
ShayneS
@johnvenets Thanks for the update.
