How to restrict access
I have a shared user with Admin next to their name for access rights. I tried to change it to restricted, but had no luck. Can anyone help?
Message 1 of 2
1,052
Do you use Library to view recordings or Feed? The app supports both interfaces. For the latter (Feed), when you are editing that person's access you should see the right arrow to change that permission. Inside is a toggle to remove Admin rights.
Message 2 of 2
1,033
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
