I connected the camera to a Wavlink Wi-Fi extender which is required since the camera is 300 feet away from the Starlink router. The camera is working great. I later added a Smart Hub which is directly plugged into my Starlink router. How do I connect the camera to the Smart Hub? The Smart Hub is turned on and the light on the front is blue which means it is successfully connected to the Starlink Wi-Fi. Since the Smart Hub is directly connected to the Starlink router and the camera is connected to a Wavlink extender (which is connected to Starlink and not directly connected to the Starlink router) will this cause a problem connecting the camera to the Smart Hub? I’ve been unable to figure it out.
If you switch to using the smarthub, then the camera will need to connect to the smarthub wifi. So it will need to be close enough to the smarthub for that wifi to reach. Connecting the smarthub to the extender LAN port is probably what you will need to do.
There is a "change network" function in the device settings, but I don't think that will work for this. If I recall this correctly, you'll need to remove the camera from your account, and then add it back using "Add device" - choosing the base instead.
Thanks so much! This has been very helpful. I suspected I would have to go this route. I think I’ll just return the Smart Hub. I don’t see an advantage to it. The camera is working great with the Wavlink extender. The only advantage to the Smart Hub seems to be the ability to save video.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
