It appears there are already some other topics about this matter, but I couldn't find a solution.
I'm running the latest version of the iOS Arlo app (5.6.2), on an iPhone 15 Pro with the most up to date iOS (18.3.2), although this has happened in previous versions.
The device has been set to trusted for a while.
Every once in a while, the app logs off, and I need to log back manually.
If I choose sending the email verification code, when I switch to the email client to check the code, the process restarts in Arlo app, rendering the received code useless.
If I choose sending a notification to the app, it's not received because technically, I'm still logged off.
So, unless there's another trusted device, or am able to access my email in another device, I'm stuck logged off.
Best answers
Enabling SMS might be another option, as you might be able to see the text message withoug switching to the message app.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
