Is the 5S-2K compatible with the VMB4000 base station? I am unable to get the base station to recognize the camera.
The article below suggests it is,
https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
How are you trying to add the camera? Mobile, desktop?
Thanks for your reply. I had originally connected the camera to my wifi network directly, not via the hub. I noticed right away that the battery was draining faster than my other "long-battery-life" cameras, and I thought it might have been the direct communication to my wifi that was causing the drain, so I wanted to connect it to the hub instead. I tried several times to sync the camera to the hub, using both the app on my mini pad and using my Mac. I could not get the camera to sync. I rebooted the hub, took out the battery and reinstalled it, ensured the camera battery was at 100%, etc., and nothing worked. I don't want a camera tied directly to my wifi (for privacy reasons), and now I'm stuck with a non-functioning, expensive paperweight.
HI @dogbert88
Can you try resetting your camera via these steps and onboard again: https://kb.arlo.com/000062880
That worked! Thank you very much.
@dogbert88 Thank you for the update.
5s
Accessing Local Storage
Accessing Local Storage.
App
Arlo Cameras
arlo not working
Arlo Pro 5
8 -
Arlo Pro 5S 2K
Arlo solar panel
ArloPro5
audio
Automation
Blinking
Cable Length
Charging
charging unit
Clicking sound
cloud storage retention
Costa Rica
dashboard
detection
drained battery
Firmware Update
live stream
low power mode
Magenta screen
metal barns
Night vision
No recordings
Online Web
Pro 5s
Risoluzione dei problemi
Routine
Table Top Mount
VMB4000
Wifi connection
Wifi loading
wind
wireless
Zones
